Hey Guys.
I posted about this a little while ago, and now I introduce my new and improved version!!
I used thicker wire than the normal coat hangers. This stuff is almost 3mm thick.
After bending and trimming, I filed a little notch into each of the "prongs". I included a couple of pics of the head unit IN the cradle (but removed from the dash) which shows a little clearer what we're dealing with. The spring clips which lock the unit into the cradle have a little "tang" pressed into them, and the notches in the prongs engage firmly on this tang, which means when you pull back it pulls the unit out, and not just the wires! You don't even have to lever outwards before you pull back, the fact that the wire is thicker pushes the springs far enough in to disengage them from the slots in the cradle. (just have a look at the pics - they tell the story better than I can)
Cheerz! :thumbsup:
Cheerz!
