Look like I need to replace my radiator. Not surprised after 8 years / 140,000kms.
Should I replace with genuine, or is a generic brand ok?
Radiators used to last for many multiple decades if the coolant flush schedule was followed (and that was with iron block, alloy heads and a brass radiator with lots of scope for electrolysis to cause problems)… So it’s wrong that people now consider 8 years a good run…
I’d consider that the current design is one of “not acceptable quality” if it only lasts 8 years…This should especially be the case if the failure is the radiator neck cracking or breaking off, unless the failure is due to lack of coolant flush (customer neglect) or a stone was kicked up and puncturing the radiator (just bad luck).
If you maintained the vehicle to factor6 standard and especially considering that many commodores had a 7 year factory warranty, I’d seriously consider making an ACL statutory warranty claim against the business that sold you the car (and or Holden)…
Whatever the case, I’d always use oem radiators if available since their fitment is guaranteed and they should just slide in without issue.
