bumskins
- Feb 27, 2011
- 6
- 1
- 0
- Location
- Sydney, Australia
- VS Executive Series 1
Unfortunately while fixing this I stuffed up the speedometer, when I was putting the speedometer needle back (trying to set it to zero)
After just completing this repair today, I can confirm that this problem can occur when putting the speedo gauge back together. If anyone is reading this thread and going to attempt to replace the little plastic odometer gear then I highly suggest you skip this step from the original guide http://users.tpg.com.au/adslv0x2/Tenth.jpg
Instead, provided you have the correct sized miniaturized tools, you can simply skip ahead and directly undo the two screws seen here http://users.tpg.com.au/adslv0x2/Ninth.jpg holding the odometer housing and circuit board in place to the back of the speedo, without the need to remove the speedo needle and fascia at all.
Otherwise when you go to put everything back together it is a b!tch to accurately zero the speedo needle again after having it removed and there's a good chance your speedo needle will not be placed back into it's original position resulting in your speedo reading incorrectly. The needle is also very brittle with age so it's best left alone wherever possible (mine literally crumbled in my hand when removing it!).
P.S. The replacement odometer gear can now be bought on eBay from a number of sellers from as little as $8.00 for a brand new replacement.
P.P.S. After completing this guide you really get an idea of just how easy it would be for someone to wind back their mechanical odometer!
