Why do say that? What's the main difference between car and home speakers, not a great deal. I've found the T/S spec's for the drivers, and it seems they would best perform in a large sealed, or an even larger ported enclosure. The desingn i have come up with, has 15L per chamber. Which could be considered around average for your car door, except they won't have any leaks. I have a Beyhringer amp which is capable of putting out 400RMS @2ohm per channel, to drive the speakers. I also have the advantage of being able to move them around, and find the best placement.
I've looked around, and i've listened to speakers around the $600-700, and it's honestly garbage for the money. Were talking single drivers,(with inadequete fq response for what i'm after) with some of the enclosure's not even being dampened, have no bracing, and noting internally to assist in breaking up the sound waves. Also judging the some of the small rear ports i've also seen on speakers this size, it would seem there was a very minimal amount of research and development hours going into the design of them.This is especially the case, with some bookshelf speakers i've seen, having a rear port, how are they supposed to mounted in a bookshelf, if they have a rear port?
And if you were to go and buy all the parts all build it yourself, you begin to realise just how cheap and poorly made some of the stuff is on today's market.
Not only that, the market if forever leaning towards 5.1, 7.1, and now even 9.1 trends. I'm aiming at a high power 2.2 setup, which in my mind when playing music, is all you should ever need.
