HSV-Paul
- Dec 2, 2022
- 930
- 2,554
- 93
- Age
- 53
- Location
- Logan QLD
- HSV Clubsport R8
Done it since I got the car and Tbh have just got used to it, but I *think* it's getting worse so wanna fix it up.
Best way to describe it is if you imagine one bolt on a brake calliper is loose, you get a bit of a clunk while the brake pedal is pressed and the pad grabs the disc.... kinda thing.
Cars auto and I can pull away rolling and press brake and it'll do this clunk every time.....
Exept!!... in reverse. Only realised the other day and had the car over a year but yeah don't do it in reverse.
Now the weird bit. I took both front wheels off and tightened up ANYTHING I could. A pull on this, a shove of that and nothing moved or seemed to give.
I *think* I have an engine mount knackered or playing up tho as I can feel that too, could the press of a brake and a loose engine mount cause this clunk? Gonna do the trick of filming the engine bay when in gear and holding brake with a little throttle trick. Did that on my SS with suspected engine mount failure and man the engine moved so much lol. Expecting the same and Tbh gonna go do it now...
Just curious as to any thoughts as I swore I was gonna take a wheel off and find one of the brake callipers loose or something but no, everything is tight.
Wanna sort it tho...
