Help!!! Saw this thread and can relate because I too have replaced EVERYTHING and my 95 v6 VS is still getting too hot. To date I have replaced with new,
Radiator Cap, Radiator, top and bottom radiator hoses, water pump, fan, thermo fan switch, fan relays, temp sender, temp sensor, thermostat, had the instrument gauge cluster repaired and the BCM module!!! I think that about covers it...
There is no water in the oil, I check the fluid levels in both the radiator and the resevoir every day and they are full and then after 20 min it gets to halfway and then slowly climbs, get to a set of lights and it will come down a fraction, sometimes a whole bar, then as I start driving again it slowly climbs, when I get to work (25 min from my home) its hovering at the last bar before hot.
I have been assured that its operating at 94deg but its completely stressing me out.
I know it got bled because I was standing there watching it happen, especially after we just replaced the radiator 2 days ago, but I can still hear a rushing water sound behind the dash when I took off yesterday morning and this morning that lasted for most of the journey. When I came home last night, it still happened but just didn't go as high as there wasn't as much traffic on the road....
Any suggestions as to what could be causing it to overheat would be greatly appreciated because I'm running out of theories and money
It used to just sit below halfway until the top radiator hose got replaced and its never been the same for the last 3 months...
