Yes it could, and if it's connected from the dimister fuse then it could explain why it's melted.[/QUOTE]Could that something extra be the sunroof?
Mmm looks like i have to take the moulds out and have a look under the sunroof switch too that cheeky wire needs following lol[/QUOTE]Yes it could, and if it's connected from the dimister fuse then it could explain why it's melted.
Yeah prob right this girl needs to have a run lol. When i take cover off to find ign switch and immob i will post pics. Also the lights on turner wiggles heaps but also stiff to turn i removed interier globe as it was getting stuck in on position needing to manually flick light switch (little extra knob to the side a few times)Your engine running all good now? LOL
Let the cheeky wire be for now, it'll still be there after you sort the engine issues..
Hows the ignition switch wires and the immobilizer box.. did you find one?
You've lost me completely here.. 'the lights on turner wiggles heaps' ummm.. indicators??? and 'removed interior globe as getting stuck in on position needing to manually flick light switch' ummm.. interior light? if you need to manually flick switch (assuming to turn it off) then why remove the globe? you do know that all switches need to be manually flicked.. right? they won't do it by themselves.. hahahaha i think i've completely not understood what you're saying, sorryYeah prob right this girl needs to have a run lol. When i take cover off to find ign switch and immob i will post pics. Also the lights on turner wiggles heaps but also stiff to turn i removed interier globe as it was getting stuck in on position needing to manually flick light switch (little extra knob to the side a few times)
Here's a little tip.. When you're removing the lower ignition switch cover surround, just be careful as the plastics around the screws (especially around the screw threads) are extremely fragile due to plastics age etc and they will shatter.. even more so when you're putting the screws back in, do not try to tighten them like at all, do it just enough for covers to fit back in place without being loose, but don't tighten screws even a millimeter passed that point or it could break and then you'll have nothing to hold the screw in place.Yeah prob right this girl needs to have a run lol. When i take cover off to find ign switch and immob i will post pics. Also the lights on turner wiggles heaps but also stiff to turn i removed interier globe as it was getting stuck in on position needing to manually flick light switch (little extra knob to the side a few times)
Lololol, im out at car now this is what im talking about! As door open alot was easier to take out globe to not forgetYou've lost me completely here.. 'the lights on turner wiggles heaps' ummm.. indicators??? and 'removed interior globe as getting stuck in on position needing to manually flick light switch' ummm.. interior light? if you need to manually flick switch (assuming to turn it off) then why remove the globe? you do know that all switches need to be manually flicked.. right? they won't do it by themselves.. hahahaha i think i've completely not understood what you're saying, sorry
So i found immobiliser but having trouble taking off cover for ign switchHere's a little tip.. When you're removing the lower ignition switch cover surround, just be careful as the plastics around the screws (especially around the screw threads) are extremely fragile due to plastics age etc and they will shatter.. even more so when you're putting the screws back in, do not try to tighten them like at all, do it just enough for covers to fit back in place without being loose, but don't tighten screws even a millimeter passed that point or it could break and then you'll have nothing to hold the screw in place.
Nope, still confsed AF.. you're showing me headlight swith now.. where did you take bulb out from that you could swith off by the switch.......... ?Lololol, im out at car now this is what im talking about! As door open alot was easier to take out globe to not forget
