Did you find anything connected to the cables going from ignition switch and did you find an immobilizer box somewhere above the pedals? You may need to move things around a bit to access things better. Remove the plastic cover that is above the actual pedals and remove the big dash lid that covers the fuses, they're all held in place by plastic pins and clips etc. Unmount the 2 relays below the steering wheel so they hang loose for now, and anything else that you'll find that lets you get to things better, including the lower section of the plastic surrounds cover of the ignition switch. You really need good light to be able to take useful pics of black and dark things in there. I don't see the ignition swith cables here, they're usually on the left side of the steering.
