All done...
1 hour job doing it first time and being careful...
I drained over a litre based on my coke bottle. It was filthy and smelly !
Ended up taking about 1.3L of clean oil before it started leaking out of the filler hole.
Pictures speak for themselves.
This is factory oil that's done just over 50 000km
8mm hex key bit and 10mm spanner was all that was needed in terms of hand tools.
The plugs have rubber O ring and they were both in good condition.
The car was not level as I could not be stuffed getting it on 4 jack stands. I just jacked up the rear. I figured that the disrepancy in oil quantity would be negligible and it seems that a bit more went in than it was drained. Like 100-200ml. She'll be right
Thread dig but...
I thought the Nulon squeeze pack would be a better idea.
No pump and it would be just like rolling up toothpaste - all of the contents would be emptied into the diff. Amirite?
Bought 3 packs to do 2 diffs and allowed extra for an OCD flush and my usual oil spillage across the driveway/under the car.
I can't recommend these - the pump is a better idea.
1. the provided tube is too tight a fit into the fill hole, so when it inevitably gets oily pushing it into the fill hole, is really difficult to shove "home".
2. the "memory" of the tube means that it keeps springing back into the shape it wants to be, dribbling more oil.
3. to make 1. and 2. worse, threading my arms around the exhaust/suspension meant limited movement to guide the tube and so I couldn't shove the tube in as hard as I would like. (there's a grubby innuendo there somewhere). I have skinny arms and hands, must be worse for bigger people.
4. to add to 1., since the tube is such a tight fit, when I pulled the tube all the way out to check oil level by seeing if it is dribbling out of the filler, means that more oil ends up on the driveway/exhaust as I had my hand twisted around car parts and the tube sprung away. (must be another innuendo here).
5. I am now commited to this method for the second diff, since I have already outlaid $66. Grrr. Will do a tube modification.
My oil was blacker than Ron's, despite being an SV6, but probably due to being 100k km. Can't find the photo.
BTW, the smell was so bad my neighbour asked if there was a gas leak.
Edit: the filler plug (which I removed first) was easy to remove after a light tap with a rubber mallet on the allen key.
