- Apr 15, 2006
- 22,904
- 21,312
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
I have a 98' v.s holden v.6 ute it has a lsd but doesn't behave like on when its off stands, after reading ur post I tried to find a harrop/eaton 28 spline "early" true trac center but I want to use PayPal to purchase one but I couldn't see that option for there websites so I started looking around and found only 31 spline "early"true trac if any one has one to sell or know of were I can go to get one the way I need too please advise, also my brother seems to think that dropping the oil out, flushing it with diesel, emptying it then putting new oi in might bring it back to life any thoughts?
Sent from my GT-I9100 using Tapatalk
I wouldn't think so, the LSD single pegs when their isn't enough friction between the cones and the LSD housing due to wear. When the cones/housing wears, the cones effectively bottom out in the housing. The only way to fix that is to machine the end face to get the proper clearance. A simple oil change won't fix the mechanical wear.
So my VS static diff (trailing) can't be removed and exchanged for the VS Calias IRS I have sitting in carport?
You can't fit an IRS setup into a chassis manufactured with the live axle diff as the mounting points are different.
Maybe a custom replacement could be Jag diff?
Not sure why you would even want to do this. IF you want IRS, the best option is to buy a vehicle with it fitted from the factory.
