RR57ED
- Feb 11, 2022
- 3
- 1
- 1
- Age
- 46
- Location
- Sydney
- VE Calais S1
ok, i swapped that bit out so i'll test it shortly after work.The board mainly does the opening and closing bit. The transponder is not a part of that. It’s embedded into the plastic shell. A small flat rectangle it has to be carefully cut out.
It communicates with the key reader which is located behind the column shroud. It has to come really close to it for it to work.
Thanks in advance though!!
