Shen Long
- Sep 27, 2011
- 962
- 359
- 63
- Location
- Roxby Downs
- WH Caprice 5.7L
I have a 2009.5 Omega…what info is needed ? if i know about it ill share
can't get to gts at moment to check but i know it has a extra relay and is own power, and a couple weather pack plug for the extended high beam and a multi plug on the drivers side chassis rail where that plugs into must be for the fog lights, thats bout all i can remember at momentI have a 2009.5 Omega…
purchased a full E1 body kit with bar lights.
need to know what wiring I need to make the bar lights work.
I would love to know the following part numbers…can't get to gts at moment to check but i know it has a extra relay and is own power, and a couple weather pack plug for the extended high beam and a multi plug on the drivers side chassis rail where that plugs into must be for the fog lights, thats bout all i can remember at moment
Found the part & the part numberif i remember once these flood waters are down and i can get to it ill see, may be a week or so not sure ill have a bit going on at that point
