Bigfella237
- Mar 14, 2015
- 534
- 526
- 93
- Location
- Far South Coast of NSW
- More cars than I've got space to park!
Hi guys, just got a motor with the engine number N968079P. ~
As above, this is a NSW Police issued number, the 8079th number issued (state-wide) in 1996 as it happens, so the block must be older than that (funny business not withstanding).
The numbers are simply issued on a first come, first served basis, there was no allocation for certain uses or areas or anything like that. Any police station could issue these numbers, and they could be issued to replace engine or chassis numbers on cars, or indeed any legal identifier that was missing, illegible, or never there in the first place (push bikes, appliances, etc.).
The police didn't physically stamp these numbers on themselves, they (usually) only inspected whatever it was to verify the original number was gone but then only did the necessary paperwork, they would then direct you to an authorised inspection station or similar to have the new number stamped.
If an engine was stolen and then recovered with it's original number intact then the police would simply mark it as "recovered", IE take it off the stolen list, and you could continue to use that number.
~ As far as I’m aware, decking a pad to remove a number and re-stamping is illegal ~
It is VERY common with a Holden V8 to machine off the original engine number when "decking" the block. There is nothing dodgy or illegal about this, some blocks need the decks machined to align them with the crankshaft centreline and/or equalise the deck heights side to side.
A lot of engine shops simply restamp the original number on the newly machined surface, some will restamp the original number somewhere else on the block too, but technically, once the original stamping is no longer visible you're supposed to have a new number issued.
Having a police number doesn't necessarily mean it's been stolen or involved in an accident, in fact, if the accident damage was severe enough to destroy that part of the block then I'd suggest it would be unusable anyway!
Andrew
