imrhoss
- Feb 11, 2012
- 255
- 1
- 18
- Location
- Melbourne
- 1996 VS Statesman, 2013 VE II SV6 Thunder Ute.
Hey mate, There's really nothing else it could be other than switch, There is nothing really more to it.(mecanical)
It could be that the conection is bad, But you more than likley could tell that, Ie, connection loose when its plugged in, Or the plug its self is physically broken.
What you might have to do is bend the connection tabs a little so that it is a tighter fit and to be sure that all the metal tabs are connecting propley.
But now it's sounding a bit more like it could be the connection, Because after you fiddle with it it work's then stop's, Just plug you're dad's switch in, play with the gear's a bit untill it stop's working then jump back under and wiggle the connection a bit and see if it start's working again, Make sure to use a known working switch so you can rule out faulty switch during the test. So if it flicker's you know it is not a faulty siwtch but a faulty connection.
All there is to it is switch, wiring, ecu, wiring, insturment cluster, So you know the switch itself is working so move on to the connection its self, then from there move up the line.
But yeh it's more likley the connector that plug's into the switch, So you will just have to do a bit of work to make sure it is a tight good connection.
If it's not that then it could be the wiring its self, There could be a dodgey wire somewhere, But that's rare to just happen all on it's own.
If all above fail's you may need to get out the multimeter and check all the wiring, By using ohm's or the beep function.
My understanding was this switch was brought in on the VT, VR/VS i thought uses a switch under the console, learn something new every day
On the back of the plug theres little black tabs. when you undo those tabs, the pins come out ( i didnt know that, happened by mistake lol) gave em a nice clean and shine and used the diagram that mwb235 posted earlier to put it back together. in the meanwhile i will buy a brand new switch keep it on the side untill my car comes back from the panel beaters then ill measure it up with the multimeter (negative to chassis and positive on the pins one at a time?) then that way I can determine whether or not to keep the switch and return it. had a lil talk with my mechanic an hour ago and he tested the old switch for me. you were right, its toast! haha. he saw the plug and said they usually never go wrong, its always the switch. I guess friday is when i will know when i test and plug everything in. vx_commodore you have been very very helpful. i appreciate your help ill let ya'll know how it goes
