Mihai
- Dec 19, 2018
- 38
- 1
- 8
- Age
- 46
- Location
- Sydney
- Vs hsv manta
Ok mate il
ok mate il go over it again do you no if the plug at the dizzy if I have to have power ther when testingEven if there is 12V on injectors, doesn't mean anything, if they're not getting the negative signal to them from the ECU then they won't work. But don't worry too much about them for now, work on getting the spark back from ignition coil (once that happens you'll find injectors will be back to working at same time). You seem to be missing some critical supply to some engine management thing for you to loose all those things. Re-check fuses, re-check relays (swap them around with others of same type in car.. like horn and headlight relays etc).. check earthing on engine to body, and batery to body.. also check main large fuses inside small box that's between battery and the upper fuse/relay block.. these loose or blown can cause all those symptoms you're having..
