This works with ALDL & OBD11.How would I know if it has also codes and is that more of a mechanic scan tool thing or could I buy one
Sweet ill have a look at getting one but is there another way I could find why it’s not firing I feel like it may be coil packs or leads but another my brother in law said it may also be CAS/ Cam angle sensor or the dfi how would I be able to tell which has failedThis works with ALDL & OBD11.
[/URL]
Here is a way it won't cost nothing.What type of scan tool would work and are there any other ways I could find the issue without a scan tool
You bought the pcm & bcm because the scanner wouldn't work & you thought no communication? oh l know, l'll replace the pcm & bcm?so I have brought a new ecu/pcm
I will definitely try this tomorrow thank you heaps I have a book that tells me all the codes and what them mean tooHere is a way it won't cost nothing.
Have a read.
[/URL]
You got a mate with a working ecotec?Sweet ill have a look at getting one but is there another way I could find why it’s not firing I feel like it may be coil packs or leads but another my brother in law said it may also be CAS/ Cam angle sensor or the dfi how would I be able to tell which has failed
Yeah I know I’m not too worried as the new came with a stage 4 memical and I can give the old one to my brother in law now a complete loss but I will definitely be doing research before trusting my friend againYou bought the pcm & bcm because the scanner wouldn't work & you thought no communication? oh l know, l'll replace the pcm & bcm?
All I can do is laugh about it now I guess ahahaYeah I know I’m not too worried as the new came with a stage 4 memical and I can give the old one to my brother in law now a complete loss but I will definitely be doing research before trusting my friend again
It has some shortcomings for VS, but if original poster has a VE as well, might be worth getting.This works with ALDL & OBD11.
[/URL]
