Thanks BlackVXGTS for the repair manual. Its quite detailed but sadly none of the links (urls) work in the document either but I assume it is complete. But the URLs refer to the other sections are akk broken, unless you go through them one at a time (all 10,000+ pages) and search for the text itself.
I guess this is one of the fallacies of Adobe Acrobat readers to make really portable documents I guess. It would be great if the document in its original form was web hosted somewhere whereby the links dont actually break and/or doesn't require download.
I am not moaning merely looking for clever ways of doing things. and it appears that you may already host it locally on your internal server instead of an external facing one, or something. by the fact that in the footer of each page refers to a localhost server in it's address.
But thanks again it has indicated to me as to which solenoid is affected by this P0787 DTC which appears to be the 3-2 Downshift Solenoid or it's Wiring
Thanks
Mat
