Keep at it, you'll get there!I'm still having positive thoughts Lex - don't seem to be helping too much though![]()
Thanks for the advice. I don't have the BCM security code otherwise I would buy a genuine key head and program it with the Tech 2. From what I have read if you have the BCM security code you can do a new key without SPS authorisation. If you copy the key (MAP and Tech 2) you need authority to do so.Those MAP keys do my head in. Glitchy data at best. I have a bag of them that have failed.
Hopefully you have the codes with the car in the user manual. They are on business card. Will have radio, key, security etc.
If you get the security code, you can have a new key programmed from scratch that won’t have any data loss or problems.
I had several that failed to communicate with the locksmiths gear and they could not copy them to make a new one. So from the security code with the car a new key was created with no possibility of data error.
Now the MAP keys that would not communicate would still start the car most of the time. Hit and miss for unlocking.
New genuine key and every problem vapourised.
That was at MrMinut and cost $120 at the time with a genuine key.
