But hang on. A WH? A WK maybe?
Try removing the cluster and see if it starts.
The Cluster info came up when I first tried to connect the car - HSV symbol build 3 by someone (didn't take a note as I expected it would remain there on start up) and build level WM I may have misread a H for an M - just seemed odd to me at the time.
This info is gone since I programmed it to Manual - it doesn't show on the Tech 2 at all it was an initial screen on the MFD.
When polled by the Tech 2 it comes back with VY SS Level 1 and all functions are correct. I have checked it thoroughly with the Tech 2 and everything functions in accordance with the levels indicated.
I do have a spare cluster in the VZ that I can use if need be.
It may very well make no difference but it is a basic step to do to eliminate any glitches. It costs nothing but a cup of tea and 35mins of your time.
If it works, it’s a win.
So I went through the full cap discharge this morning. Then turned the key to on, went through its sequence and MFD read systems OK. Confirmed with the Tech 2 that the communications errors were historic and the no start anti theft was also an historic DTC. A glimmer of hope.
Checked communications with all of the modules - 100% (less radio)
Followed the serial data diagnostic steps and came up with System OK.
Turned the key
Crank, crank, crank
Repolled the BCM - three lost serial data messages are now current - PCM, ABS and Instruments
Repolled PCM - P1626 Theft Deterrent System, Fuel System Enable Circuit is now current
So brains trust - I have detailed my diagnostic process so far below. Have I missed something obvious and am I heading in the right direction?
When the key is inserted into the ignition switch cylinder the BCM polls the key through the slip ring and contact pin to check the remote code on the key using the remote code reader. If the code is correct the BCM deactivates the theft deterrent system. Well the security light on the instrument cluster is off as per the circuit description.
(BCM is able to communicate with the instrument cluster)
The system completes it self check. The Instrument Panel Cluster provides visual information to the driver via the MFD. This means that the instrument cluster is sending and receiving serial data.
From the Manual (with my problem solving thoughts)
On vehicles with a GEN III V8 engine, the BCM polls the PIM and sends an encrypted BCM / key security code when the ignition is turned on.
When the ignition is in the on position I can only see historic DTC. So at this point everything is good!
The security code is received via the BCM slip ring, or via the remote receiver in the event of no slip ring communication. The PIM compares the received security code with its stored security code and if the codes match, enables continued engine cranking
The engine cranks so the PIM receives the code. Correct? Otherwise engine cranking would cease (I expect)
and sends a separate encrypted security code to the PCM. The PCM compares this code with its stored security code and if the codes match, enables injector fueling to continue. The PIM returns an OK TO START message to the BCM, which tells the BCM to jump from SHORT
LOOP mode to LONG LOOP mode.
I expect this is the failure point and there is a mismatch between the code in the BCM and the PCM. The PIM is not involved other than to transfer the data between the BCM (UART - fixed pulse 5V to ground @ 8.3kbits/s) and the PCM (Class 2 Comms - long/short pulse 0-7V @ 10.4kbits/s)
So during the start up sequence the PCM shuts down the fuel and ignition circuits as part of the theft deterrent system. It does so because either there is a mismatch in the code or it loses communication with the BCM.
So now to determine if comms fails or the PCM isn't linked. TIS2000 required I think!
