It is best to not buy this unit until kayhan sorts a massive issue out and that is selling you a unit that you only have "user" access to and not "admin" access.
they have passwords set on most of the options needed to do something as simple as remove your google account which is stupid.
the play store will update and you will not be able to access it because you need to re load your google account and you will never be able to remove it or factory reset or access developer options in the current state they are selling it.
so it is definitely something to stay away from until they decide to give the passwords.
Why don't they supply passwords for an item you spent good money on and now own?Interesting, tried any of the common passwords Kayhan has used for the other units?
The usual reason given is "we don't sell you only the unit, but also the settings in that unit which makes it work properly; and it took us time & money to develop those settings & hence if you want them changed we will charge you extra for that extra time".Why don't they supply passwords for an item you spent good money on and now own?
Just another good reason not to buy it...The usual reason given is "we don't sell you only the unit, but also the settings in that unit which makes it work properly; and it took us time & money to develop those settings & hence if you want them changed we will charge you extra for that extra time".
Which makes more sense with an aftermarket ECU tune than a head-unit … I don't know if there are even settings they need to maker that the manufacturer didn't?
I am not sure what they are but 123456 gets you into the extra settings under the vehicle settings option.Interesting, tried any of the common passwords Kayhan has used for the other units?
2: really bad glare/reflection on the screen so some sort of antiglare film is needed.
