sundaydriver
- Jan 9, 2017
- 122
- 6
- 18
- Age
- 44
- Location
- Queensland
- VH 202 Blue 3.3 Vactioner
1983 VH 202 3.3L straight-6 with the Varajet II.
I am getting ~15 inches/mercury vacuum. Which puts it in the 'late ignition timing' zone on the vacuum gauge.
The effect of this a jerky acceleration at low speed @ initial take off. Occasionally a hesitation when taking off hard at very low speed or stationary start.
I image there are other peripheral side-effects (maybe loss of power, and fuel efficiency?) but the acceleration issue id my main concern.
I can only get the right vacuum (~18 steady) when I advance the timing to roughly 25-30 (guesstimating, because the timing marks on the block only go up to 12). Unfortunately, this puts the RPM up to 1300. I can bring it down to 1100, but that seats the idle bypass screw. Doing it the other way round (correct timing, but raising the idle RPM with the bypass screw) gives a similar, but no where near as smooth, result - i.e. very shaky, 1000 RPM, and a wobbly ~16-7 vacuum.
So it's either correct vacuum with stupid-high RPM, or correct timing with the acceleration issues, and a slightly shaky idle.
- I have correct ignition timing (~6-8 as suggested by workshop manuals) and that's based of correct TDC (timing mark on balancer is at 0 when cylinder #1 is at TDC, and the rotor and dizzy mark line up)
- I have checked for vacuum leaks, and can't find any - done the spray test, smoker, and propane test. All reveal no leaks
- The head gasket is fine
- I have replaced valve stem seals
- have cleaned all the lifters
- Pressure tests (wet/dry) all tight and normal - ~150-155PSI
- New ignition system (module, leads, rotor, dizzy cap, wiring, and plugs)
- Carby has been rebuilt (all jets are clean/new, new needle/seat/float, gaskets) and idle mix and bypass are good. Idle stop has not been altered
