- Apr 15, 2006
- 22,673
- 20,656
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Well you have something hooked up wrong because at idle there should be vacuum on the distributor advance module.
Different locations on the intake manifold provide different levels of vacuum. The vacuum tree on the rear runner will provide a more constant high vacuum source which you need to keep the brake booster happy.
For manifold vacuum readings you really need to measure vacuum at the common plenum which is under the carb.
Ported vacuum is used by the various switched on the engine to limit vacuum advance on the distributor in a poor attempt to reduce obnoxious gasses engines produce before the advent of unleaded fuels and catalytic converters. The down side of these measures (reducing ignition advance) was that it also killed engine performance.
