My Vl
MoonDo44
new zealand
1988 VL GTS
Had a bit of time to work on the car over the 2 weeks.
both engines have had the heads and intakes removed, and have take them into work for cleaning.
The first one was pretty bad and had a blown gasket, the second was a lot cleaner and looked like it has had some work done to it.
But the cooling system of the second one has rusted out in parts so the connectors are breaking off when removing parts.
So it looks like that it will be an engine built from 2 half's.
Also the rusted out body is 90% ready for a trip to the scrap dealers as it is no good for anything else.
Ill add some photos when I can get so in the day light.
MoonDo44
new zealand
1988 VL GTS
The Last Few Months
So been busy with work over the last few months, that and its been to cold to do a lot of work, however I managed to get a bit done:
Old Body
The last of the parts where stripped out of the rusted out body and it was send to the scrape metal dealers for beer money.
Spare Parts
Had some time to do a quick inventory of all the spare parts that are stored at a mates place.
Starter Motor
Started to clean and paint the starter motor however when I stripped it down the plastic cog inside feel apart, so I had to get the second one for storage which looks to be in better condition.
Spare Tail Light
Took one of the spare tails lights apart as I have a idea on filling it with LED's, still trying to work out if it is going to work.
Engine
The engine and gear box is fitted awaiting a timing belt. As well as the head with new head gasket.
The radiator has been flushed, pressure tested and paint awaiting proper fitting.
Bonnet
Fitted the bonnet, mainly for storage but also to test out the gas struts.
And lastly a cover to help keep to clean and dust free.
MoonDo44
new zealand
1988 VL GTS
Just a quick up date with a much larger one to come soon. As you can see there are lots of parts ready to go on.
MoonDo44
new zealand
1988 VL GTS
Help! small fuel problem
So I was installing the fuel pump and lines when I came across a problem. The fuel tank is missing all its lines, which I knew about, so I looked up how to replace then. Which is easy but the problem I'm having is the fact that my car was NZ build and from what I understand is the fuel lines are run some what different than an AUS build one. So now I can not work out how the lines are meant to go and I am confused. Can any one help shed some light on the situation? Because the return line comes up past the pump not towards the tank.
MoonDo44
new zealand
1988 VL GTS
big-ish update
So here it is a big-ish update. There is more to add later but these are the only photos I have at the moment.
Here is the test fit of the new relay location. It looks good I just have to test fit the dash over top.
Replaced the brake booster and master cylinder with a VS/VT combo. Just wanting for the line adapters from aus.
Had a problem with the key and it kind of got hit with a hammer. So after that I went and completely removed it and the housing so there no longer a key.
Diff and drive line are in. Im just wanting on a set of rubbers for the top of the springs.
dingeldei
Statesman
looks awesome cant wait to see it finished
MoonDo44
new zealand
1988 VL GTS
So... Here's a update
So with an unexpected work trip oversea's that took over a year out of project time. I finally gotten back into it and have a little bit of funding. Ive been working on the electrics so that I can get the engine running. It's been sitting for all the time with out any care.
I have mounted a distrubtion block by the drivers right foot to break down the large 0 gauge cable to smaller more usable ones.
From the disturbtion block it breaks down smaller.
Did a bit more work on the relay panel making it cleaner and added 2 150a relays to work as the ignition switch.
Up by the rear vision mirror will be mounted the 2 main power switches and engine start button.
All through there is still a lot of work to do.
The old girl now also has a little sister to keep her company at night
MoonDo44
new zealand
1988 VL GTS
Not much done this weekend, just fabricated a panel to hold the new fuse panel that is coming and the distribution box for the 3 main power cables.
The fuse panel will accesable through the hole where the vk panel is.
MoonDo44
new zealand
1988 VL GTS
S**T Happens
So this happened... Snapped a bolt.
And Im still trying to get the spare apart but not matter what I do it just wont undo. I most be doing something wrong.
So I messured up where to run the main power cable from the starter to the alternator.
Lastly the new fuse panel has shown up. It has now been fitted to the steel mount.
