as minx said replace the seal and fix it properly first go,instead of trying additive that most probably wont work
Yes the additives can work, I used to work in an automotive parts store where they sold SuperX products, the additive for engine oil leaks contains chemicals that soften the oil seals which go hard after a while and won't close the gaps.
My son had a Nissan Navara with an auto, it leaked from it's seals and were quoted at $2k for an overhaul repair. After using the SuperX Auto Stop Leak no more oil leaks and it lasted for years until he traded it in on another car.
So as I said it can work and work well, but depends how bad.
How is it NOT GOOD for the engine?Any additive that actually works IS NOT good for your engine, if it can fix a leaking seal imagine what its "fixing" in the valve area etc.
