Glaze
Doing a bit of hunting on the shed ornament. Chasing a leak either sump gasket or rear main. I’ve attached a YouTube vid of what I recorded.
Around 40-50secs oil can be seen seeping slowly from sump bolt before the bolts that holds sump to rear main seal plate. Towards the end of the vid, the flywheel cover is seen with oil on surface.
It leaks like a waterfall (car is on ramps). Needs a good clean haven’t got a chance to do it rockers leaking as well.
My guess is sump gasket since oil is seen seeping from area before the rear main seal. Any advice appreciated cheers
VX Calais
VX Calais
