Silver07ve
- Feb 16, 2023
- 104
- 52
- 28
- Age
- 22
- Location
- Victoria
- VE 3.6L Omega
I haven’t had the car for a very long time, yeah I need some parts cleaner,You need to clean it right up first, then look and see where it’s coming from.
This looks like it’s being going on for months or more perhaps?
Is that correct?
I might do the all of them at the same time but I’ve gotta find the time to even do it all, I’ve looked at the pcv mod and I cleaned mine out but I don’t have the right sized drill bits but I need to get some to do it,That’s a familiar one. Bottom left corner of the timing cover is where it’s coming from. I thought ours was the trans hoses there, but nope. It was engine oil.
It’s a semi big job and considering balancer needs to come off and the front cover, you may as well do the timing chains and oil pump while you’re at it.
I’ll bet my left nut that once that’s cleaned up, you’ll see oil dripping from the bottom corner and more of the oil appear again over coming weeks. It will escape while it’s running, not noticeable at idle.
Take a look at doing the PCV mod which will relieve a great deal of the crankcase pressure. It costs nothing to do other than your time and will relieve the engine of the pressure that builds up with the engine running.
I brought it off my father in law and still I’m his name for nowIf OP got RWC with this car just not long ago it should have been clean when purchased.
