GoodTimes
- Jun 18, 2012
- 255
- 2
- 0
- Location
- Chirnside Park, Victoria
- 2011 VE Thunder Sandman, 6-speed Manual
So I have my VK with stock 202. My mate had a 202 built for him for $5,000. He no longer wanted it so I purchased it. I ripped my tranny and everything out of my car and the engine was orginally going to be manual. It had the flywheel on and spun over by hand. There is no spark plugs in it. So I took of the flywheel and bolted on the flex plate with the humps going outwards for the Torque Converter to bolt onto and no the bolts were not to long and didn't hit the block. Then the crank will no longer turn over, I'm thinking what the #### and so after ages I could not turn it. I thought what a load and put flywheel back on, nope no spinning.
Put two bolts in the harmonic balancer and jammed a massive breaker bar in there and tried to turn it and all I did was snap the bolts. But I used a crow but against the guide points for the auto box and the teeth of the flex plates and it turns over sweet, just hard. WHAT IS GOING ON!?!?!?!?!?!
Sent from my GT-I9305 using Tapatalk 2
