"OP found the pcv valve changed it all done"Pete wouldn't' OP's primary issue be from RHS main foul air PCB connection post TB?
I understand the 5% that may gunk up from least resistance pre-TB with WOT / low MAP but surely it’s the 95% of gunk that comes through the RHS main PCV directly into the plenum that gunks / cokes up the valves in a SIDI?The back flow via the clean air side is what gunks up TB and IAC's and causes all those little troubles you see with old high mileage engines.....
So the series 1 L98 is affected? I only ask as I have one and my local mechanic/ LS performance engine builder who is well respected here in NZ told me not to bother with a catch canA working factory air oil separator on port injection is no drama in my experience.
Few owners realise that the VE SS had a faulty AOS design (which meant the LHS rocker cover) on Series I was rectified a few months after release of Series II L77, in Feb 2011. So the prevailing internet (US) evidence is that all G8s whether L76 or LS3 needs a dodgy DIY draining catch can to empty the poor stock AOS mess.
However the LS3 has never had the issue, and the L77 was fixed with a recall for early Series II.
Being ethanol port injected, a little bit of upper valve lube doesn’t hurt.
The L98 has a different PCV system, has an LS2 valley plateSo the series 1 L98 is affected? I only ask as I have one and my local mechanic/ LS performance engine builder who is well respected here in NZ told me not to bother with a catch can
