Ok, it’s a bi5 of a thread dig and it’s also time I pulled my finger out and finally hard wire the ctek battery charger to my car but I hope to do it a little differently…
The following electronic trailer braking post gave me some thoughts but has raised some questions which I hope the forum members can help with.
Next to the battery in the VF trailer light loom is a 2 pin connector which has the blue wire for the trailer brakes and the brake light signal for the controller. I havent been able to source the mating connector so may have to cut it off and use my own connector. Does anyone know where the connector could be purchased?
I expect that I can use the service brake control pin and earth pins on the female connector and wire up a ctek connector to a male 7 pin plug. Then it should just be a matter of plugging in the home made ctek to 7 pin trailer adapter when charging the battery. This should be possible as I already have a tow bar and won’t ever be using the trailer service brakes…
The only question is what else, if anything, is connected to the trailer loom purple service brake wire (5) going to the above mentioned plug next to the battery, what current is is designed to handle and whether this is equal to or greater to the ctek’s 5A… . A related question is where the trailer earth connector is actually bolted/connected and what current it can cope with.
A circuit diagram and layout/routing diagram for the VF trailer wiring could be helpful in answering these questions. Does anyone have access to such and can post as the VF workshop manual PDF is a little deficient on this front and doesn’t even show enough detail on page 8892.
Also, does anyone know here one can get the male connector for this accessory trailer brake harness (part number?) as that’s a part I haven’t got and such would also helpful in making it idiot proof and fully reversible.
As is I have the 7 pin plug
https://www.jaycar.com.au/flat-7-pin-line-plug/p/PP2050?
I have the ctek battery charger eyelet terminals
https://www.repco.com.au/en/globes-...erminals-56-260/p/A9337381?kwSearch=terminals
and I have some misc bits for the in boot side, just not the factory male connector.
Help appreciated.
