vf2calaisV8
- Dec 9, 2023
- 2
- 0
- 1
- Location
- Perth
- 2016 VF2 Calais LS3 V8
I was occasionally towing a 2015 Jurgens Lunagazer with my May built 2013 VE Series 2 SV6 Z-Series red hot sedan, until I got rear ended on my way home from a tax appointment in October 2023 and the car was declared a statutory write off by Shannons Insurance as the towbar bent 2 chassis rails when being hit by a Jeep at nearly 70km/h.
However the VE kept the battery voltage above 14v the entire time, unlike my '08 60th anniversary VE that had the battery draining issue, and kept the fridge running in the Lunagazer for the entire trip.
I've since purchased my 2016 VF Calais V V8, it and my Dad's 2016 VF SS will drop the voltage to 12v when the battery is charged, and the caravan's fridge turns off when the voltage drops below 14v as it thinks the car isn't running so it doesn't drain the battery
Is there a way to get the VFs to constantly output 14v when towing?
The car is aware it's towing as the merging indicator flashes 6 times instead of 3, and revs higher before shifting gears. It has a genuine holden 2100kg towbar I bought from the wreckers 2017 VF SV6, with a genuine wiring kit I bought on Ebay.
The fridge is powered by an anderson plug, attached via a relay directly to the battery in the boot. The relay is turned on by the accessory connector behind the glovebox, which also powers the electronic brake controller, but only when the car is turned on. It does not come on when remote starting, until I get in the car and press start/stop. This setup was all pulled from my written off VE.
