snoozey187
ripperthetripper
- Apr 7, 2012
- 3
- 0
- 0
- Age
- 41
- Location
- brisbane
- vx commodore
Cant find cause of several problems, any idea's appreciated.
Vx series1, Bad vibration/ shudder on drivers side when braking mostly down hill from 100+k to any from 80-60 km. Replaced all front end bushes, pads and dba rotors. New tires, alignment, balance done. Checked suspension and within tolerances. Had 4 Different mechanics look at it and no luck. Possible rear rotors? Warped Hubs? Faulty abs. No fault codes are displayed.
The other issue is puzzling me, I have run out of fuel twice, dist to empty drops dramatically no matter how easy i drive from the 1/4 tank mark. The Problem is not running out of fuel, its when i fill up i can only cram 63 liters max into the tank. Replaced all filters, checked lines reset cpu to no avail. Is there any point in dropping the tank? It is a 75lt tank????
Appreciate any and all feedback on these issues.
Regards,
Nick.
Regards,
Nick.
