Hi guys, I'm having a bit of trouble getting the actual bearing out everything else snap rings etc is out.
Anyway for those of you who don't know how to get to it, once you have removed the driveshaft there is about 6 hex bolts you remove. once those are out there is a "Cover" on each side of them that you have to tap out using hammer and flat head keep rotating and tapping it will take a while, you need to take the rearmost cover out and frontmost too I think. Once the rearmost cover is out clean the grease to see better, there is one snap ring to remove, once it's out.
You can tap the joint that is all greasy out, there is a section where you can tap it out from behind.
Then you have to remove another snap ring. Once that is out you have to remove a plate to get to the bearing, doesn't matter if you break this plate or bend it a new one comes with it.
I am stuck on getting the bearing out itself, has anybody removed it without a press? I tried holding the whole shaft upright and having a friend hold the rubber section of bearing while I smash into the top of the shaft so the shaft goes in and bearing comes out but the rubber part sort of acts like an absorber and absorbs all the force. Then tried going on bench and front behind it hitting the bearing with hammer and screwdriver, at the rear it separates but at the front it's not moved out at all.
Any ideas?
