Thats the earlier models.The plenum/LIM gasket should be rubber 'pairs' of 'o' rings.
I think @krusing means the pcv valve?
I did the lim gaskets last year, the kit l got was from repco. The gasket between the lim & plenum was paper, very thin cardboard. Like yours it tore.
I took the old steel one & used a very thin rtv gasket on either side of the metal gasket.
Then took the lim back off. Had some used mace metal lim gaskets, so cleaned them back up, & replaced the crap repco ones.
I'm assuming you used the orange end seals for the ends of the lim?
While doing the end seals did you put a dollop rtv sealant on the corners?
I used a thin rtv sealant over all the surfaces orange seals.
Lastly did you connect the small hose from under the throttle body?
Your on the BallYes the EGR valve has a spring. Seeing you will have to take plenum off to put the spring back in, replace the (knackered) gasket.
The plenum/LIM gasket should be rubber 'pairs' of 'o' rings.(Pictures taken from Gregory's workshop manual.)View attachment 258376View attachment 258375
No the egr pipe dosen't have a spring, But the pcv does. There's also a oil separater sits in the bottom then the pcv, then the spring.Does the EGR pipe have a spring in it? That’s the only piece left over from the entire job
Looking at the image with the PCV valve in it,Yes the EGR valve has a spring. Seeing you will have to take plenum off to put the spring back in, replace the (knackered) gasket.
I'll post a pic of one a little later. I'll grab a pic now.
