Spare Tyre Difference
Michael_J
SA
'97' VT Wagon
As I went outside for a cigarette I noticed the front passenger tyre on the VT Wagon was flat. However the tyres on the car are 215/60R15 and the spare is 205/65R15. So I was wounding if it's okay to place a different size tyre to the others on the car, I drive a lot during the day for work so I'd like to know if it's possible or if it will create problems.
I am unable to have the flat tyre replace for a further 12 days.
Cheers.
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
As the spare is within 1% (circumference) of the tyres on the car currently, it won't be a problem for the 12 days, however you "should" always have the same tyre sizes across the same axles i.e. same on the fronts & same on the rears. Tyres pressures should always be maintained & checked regularly! Once the flat tyre is repaired put it back on the car.
215/60/15 = 2008mm circumference or 498 revolutions per kilometre
205/65/15 = 2034mm circumference or 491 revolutions per kilometre
Michael_J
SA
'97' VT Wagon
Thanks for the help! :)
Only got the car a week ago, so still in the process of making sure everything is correct and okay on the car.
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Yeh that be fine, no issues
Just pray you dont get another flat
As for flat tyre, whats the issue? sidewall damage or a damage in the thread.
If the thread, should be able to repair for like 20-30 dollars
Sidewall damage unable to repair
Michael_J
SA
'97' VT Wagon
All good and repaired. Was a damn nail lol
