Steering wheel removal, stuck
wildfiremaint
VR SS , 2007 Subaru LIBERTY Wagon
Hi Losh, Iv'e been following along with your steering collumn problem for a while and thought
of something.
The steering collumn on my VR SS is adjustable Up and Down and also Backwards
and Forwards.
Could it be that the column has been adjusted too far forward ( when the wheel was off )
and preventing full insertion of the wheel when attempting to put back on.
I guess that a VS may not have an adjustable steering wheel anyway.
Just a thought. :)
losh1971
North Tas
VE Series I SS Ute
of something.
and Forwards.
Just a thought. :)
VR's have adjustable column but not ute, or at least not column shift ute.
losh1971
North Tas
VE Series I SS Ute
Anyone else have an idea? I thought maybe the shaft was 90deg out but I don't think it is, as the inside uni joint wouldn't have fitted as the bolt slot would be out too.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Any Column Shift model has no personal adjustment in any parameter. They are just a solid bolt up.
vc commodore
Like the Leyland Brothers
VC, VH and VY
Little update...I happened to be in the right place at the right time for @losh1971 and found a replacement steering wheel for a very very cheap price....Just got to head back to the place tomorrow, where I found it and remove it for him.
When he gets it, there might be more additions to this thread when he gets the new steering wheel :p
vc commodore
VC, VH and VY
Can't be...The shaft rotates 360 degrees.....The shaft also fits in one position on the rack shaft....(Hope that makes sense)
losh1971
North Tas
VE Series I SS Ute
No I was thinking 180deg not 90, oops. Yeah ok well it can't be that then. I have no idea on how to centre the firewall uni joint. It wasn't a problem until I fitted the wheel two days ago. Last week when I had trouble it wasn't off centre, or at least it wasn't rubbing and squeaking and no knock/click either. Although it takes a full lock to get click/knock.
the_boozer
no more VK
51
Shitsville Morwell
hilux
I think the column has collapsed if you hit the shaft removing the wheel, possibly why the bottom bearing is moving .
vc commodore
VC, VH and VY
Is there a bolt holding the column to the pedal box? Is so, is there a little slop within the bolt hole, to allow you to move the column up and down a little bit.
Worth looking at to help solve your issue
losh1971
North Tas
VE Series I SS Ute
Nope not collapsed I took the measurement. Bottom bearing is not loose either.
