adios57
- May 4, 2005
- 16
- 23
- 3
- Age
- 66
- Location
- Sydney
- VE Commodore
This is from my notes which were after going through the wiring diagram which could be wrong.
It is the air conditioning control module
Connector A 2 wires A1 From fan motor orange
A2 Black to body earth behind kick panel on LH or RH on climate control
Connector B wires B14 from fuse F2 engine compartment Orange/green trace
B10 low speed serial data circuit diagram 31 green
B6 Demister relay white/blue engine compartment
B13 A/C Compressor green
B12 A/c compressor blue
B12 electronic displacement valve in air compressor blue
B13 electronic displacement valve in air compressor green
Climate control models use Connector B in order B4, B5, B2, B1, B8, B7
Connector D 7 pins RH air mix
Connector E 11 pins Auxiliary Air mix 5 pins
Auxiliiary air mix 5 pins
Large connector C Fresh recirculating reverse at pin C16 white/blue trace
C15 White /black
C9 Blue/black
C6 White/red
C20 White/green
LH Air mix C13 white
C14 yellow
C10 black/red
C5 black/yellow
C19 black/white
RH mode motor C11 light green
C12 orange
C22 light blue
C4 red
C18 pink
LH Mode motor C2 brown
C1 black
C21 Blue
C3 grey
C17 Green
Evaporation sensor Black to C8
Black to C7
I hope these help someone.
C15 White /black
C9 Blue/black
C6 White/red
C20 White/green
C14 yellow
C10 black/red
C5 black/yellow
C19 black/white
C12 orange
C22 light blue
C4 red
C18 pink
C1 black
C21 Blue
C3 grey
C17 Green
Black to C7
