VT series 1 V8 uses the same bearing as the V6. The same bearing is used from VC I believe. I know it's the same back to VR.
Hey I have a Holden Commodore series 1 VT with a 5 L manual Getrag gearbox, My rubber coupling on the tail shaft basically keeps exploding I’ve been told because I don’t have a centring bush does anyone have a diagram of what it looks like and where exactly it goes, an does anyone know where I can buy a new coupling an centring bush from. I tried a few parts shops around townsville, I’ve been told you can only buy them as genuine parts, I tried Holden they said there’s none in Australia. I have seen a few online but They’re not for a V8. if I new the dimensions of the bush I could get one made. Any ideas…
Who told you you need a centering bush, the people who have been replacing the coupling or a mate ??Hey I have a Holden Commodore series 1 VT with a 5 L manual Getrag gearbox, My rubber coupling on the tail shaft basically keeps exploding I’ve been told because I don’t have a centring bush does anyone have a diagram of what it looks like and where exactly it goes, an does anyone know where I can buy a new coupling an centring bush from. I tried a few parts shops around townsville, I’ve been told you can only buy them as genuine parts, I tried Holden they said there’s none in Australia. I have seen a few online but They’re not for a V8. if I new the dimensions of the bush I could get one made. Any ideas…
Are you referring to the CV or bearing. When I bought my gen bearing I'm sure the part number was same right back to VC. The CV I wouldn't know as I've only replaced the centre bearing.
No I’m referring to the centring bush which sits on the end of the tail shaft inside the rubber coupling to keep it centredAre you referring to the CV or bearing. When I bought my gen bearing I'm sure the part number was same right back to VC. The CV I wouldn't know as I've only replaced the centre bearing.
Rubber Couplingcoupling? or center hanger bearing?
