LachieKb
- Jul 27, 2017
- 35
- 23
- 8
- Age
- 23
- Location
- Nsw
- VE SV6 Ute
I’ve been having issues with my MY2010 SV6 ute, and I now have a couple options to finally fix it, but both will be pricey and I’m not sure which I’m better off doing. TL/DR at bottom.
The first issue is that the 2 centre cylinders are down on compression (both 100psi while the other 4 are roughly 150psi iirc) and they are burning oil. We’ve discovered this issue stemmed from using a cheap air filter which didn’t seal well allowing a fair bit of dust to get into the intake. This issue was only discovered when the car damn near ran out of oil just before the 225,000k service (my bad for not checking often enough), which caused the timing chain tensioners to lose oil pressure when coming off throttle, making the chains slack and make noise.
Soon after this the second (and more annoying) issue arose. The engine would suddenly lose about 50% of its power (mostly above 2k revs), making highway driving very difficult as it barely has the power to get up a slight hill without dropping 2 gears. However the engine still starts easily and runs smooth, just like normal, you only notice a change when you put your foot down and it barely moves. Also, the power comes and goes, seemingly randomly. After driving with no power for a while it will sometimes completely come back like normal while waiting at the lights or after restarting the car, and it will remain for maybe 10 minutes (or rarely, much longer) before disappearing in the same fashion. It’s completely random and I have not found anything that causes the power to come or go.
This behaviour and a throttle position fault code made us think it was a faulty throttle position sensor, but replacing the throttle body made no difference (although that code did not reappear). There were two other codes though, P0420 (Catalyst system efficiency below threshold bank 1) and P0008 (Engine position system performance bank 1). The second suggests the timing chains are stretched and/or have skipped a tooth, throwing out the timing. We now think this could be causing the power loss issue (although still not sure why the power comes back). We aren’t sure about the other code, but guessing its a result of the poor engine performance.
So now I see I have two options:
1: buy a timing chain kit for about $600 and install myself, and just keep topping up the oil until I can afford to rebuild the engine later, or
2: swap my busted LLT engine for a newer LFX engine because LFXs are cheaper, easier to find and better than LLTs.
My main concern is cost of parts. I have the means to install it all myself, but I have very limited funds right now. I know doing the LFX conversion will be difficult and will involve swapping the loom and ECU and reprogramming BCM, but it would probably be the better and cheaper option in the long run considering the cost of rebuilding and maintaining an ageing LLT. I’ve seen guys on the forum claim they’ve picked up LFX engines for $500-$1000 a couple years ago, but unfortunately doing a quick look online now I can’t find any under $2200. If I can find an LFX with under 150000 ks for under $1500 I’d probably do that over rebuilding my LLT, but is that wishful thinking?
TL/DR: my LLT has 230,000ks and needs a rebuild and timing chains replaced. I have limited funds. Should I spend more rebuilding it or bite the bullet and LFX swap it for better reliability in the long run?
