alloytec sludge
dam it thats a lot isn't it
Hey mate I had same problem with my v6 ve alloytec the windscreen wiper switch was gone and would shut down car but turn it off and start no problem after me trying to power wiper motor my with engine harness unplugged the motor work put back together no cranking but power to dash. And radio then the wiper started bussing when key with on I pulled out check no earth to pin 86 I believe crank relay and wiper share there earth but if I pull out wiper relay and just earth pin 86 key switch work car runs perfect I’ve pinned it out no earth and I’m marine mechanic so I’m unsure if it’s ecu or wiper switch if you could help would be appecatied thanksthis works then here is the diagram you need
so depending on which leg of the relay your connecting an earth too....
pin x1_86 is earthed inside the ecm PERMANANTLY so if no other fault i would just earth that wire
if it didnt cause engine light and all worked just earth it
from what youve described to me
x1_87
x1_30
x1_85
is good circuit all except x1_86
so if circuit between x1_86 (pin 86 on relay) and pin x2_35 (on ecu) is not open circuit or high resistance
and its an auto or if manual the clutch switch is operrating correctly (disengages cruise control? or get it checked with scantool)
then the fault is inside the ecm
http://forums.justcommodores.com.au...ed-picture108389-x1-x2-04vz-ecmconnectors.png
theres the ecm connectors good luck man~!
