V6 Performance Parts - L67
MACE
g'day MACE starting to work my L67 gonna do all the intake first just wondering, with more boost if I fit the 69mm throttle body and your ported flow meter it will have alot less restriction and could suck thru more air? correct
more air, bigger bang, more ponys at the wheels
Hey ducker85,
That's correct however you'll need a custom tune for the ported MAF
Steve :)
wogstyler
nth qld
VX Acclaim sc L67
in my opinion, if you goin to get a bigger maf and need a tune for it, just get a mafless tune. Even less restriction if you worried that much about it. The only trick is finding someone who knows wat they are doing to tune it right!!!
Be careful who you get to tune it and do your homework on them before giving them your car.
MACE
I agree with what your saying wogstyler, especially the part about a proper tuner!
Otherwise they metering methods have there pros and cons. If you go a proper bored out MAF the restriction is fark all ;) They also are cheaper to tune and look factory like and work with the factory piping off the bat. Plus they are more tolerant to any engine changes as they directly measure air consumption (more accurate metering) unlike a map sensor which does not. As a result the computer need to calculate air consumptions using feedback from other sensors hence being less accurate and less tolerant to change
ducker85
Narnia
09 VE clubbie R8
Hey ducker85,
Steve :)
could I just reset my computer n use it untill i get a few more mods done (boost n exhaust) and then get a tune or would i be better leaving the ported MAF off untill the day i get the tune?
VY03
42
Margaret River
2003 VY Acclaim
Better off leaving the ported maf for now as it needs a custom tune to run right as the factory tune won't work eg idle rpm all over the place
wogstyler
nth qld
VX Acclaim sc L67
I agree on the maf tuning but it also depends on the future of the mods. eg, With a A2A cooler it is alot harder to tune with maf in as the air has a long way to travel between maf, tb, engine. You will most likely get a flatspot.
they alot easier to tuine with a W2A cooler.
MACE
Depends on where the MAF is located though ;) In an air to air setup it's best to put the MAF after the intercooler plate
wogstyler
nth qld
VX Acclaim sc L67
yeah i can understand that MACE :)
But while i got a W2A I have to say they are best lol hahahahaha.
wogstyler
nth qld
VX Acclaim sc L67
nah it a stealth lol. I just havin a joke :)
Wish it was bigger!!!!!!!!!!!!!!!!!!!!
