J_D 2.0
- Mar 20, 2020
- 2,965
- 6,996
- 113
- Location
- Ipswich
- 2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Hi All.
Im looking at converting my SV6 from the 5 speed auto box to a 6 speed auto box. I know your thinking “why would you possibly want to do that” to which I would say the 5 speeds are rare as rocking horse sh1t and expensive af whereas the 6 speeds are a dime a dozen.
The box that’s in it is on the way out and a reco 5 speed box is 4k, a good second hand one (if you can find one) is nearly 3k from what I can see. If I’m into the SV6 for the long haul (and I am) I’m better off changing to a gearbox that is more common.
I suspect that not too much mechanically would need to be changed but how would the electronics be dealt with? Can you just get an ecu from a VE S2 and use that? Would you reprogram the existing ecu?
On the cost differentials alone if I can do the conversion for 1500-2000 plus the cost of the gearbox at around 1000-1500 I’m ahead and get the bonus of an extra gear plus easier servicing/replacement down the track.
