Hi mate. Would you have happened to take a pic of the pins used on the doc?I too used this quide and connector to instal blackvue DR650 2ch dashcam with power module in my Redline.
you found a RAP in the boot?I found the RAP (thanks to another post on the forum)...in the rear near the battery, hooked it up to my PS8! All good! Pretty easy to find as well. I pulled the fuse and put a wire into the fuse holder, then put the fuse back in. Will put a pic up to show!
I did yes. The pins in my MY16 Redline were exactly as per the previous posts. Be careful the plug is not the wrong way around compared to looking at the pics.Did you use a multimeter to confirm the pins? My mate who did the wiring part said that the pin #'s advised on page 1/2 were different to my Redline DOC, so he used a multimeter to confirm 12+, acc and earth. He did mention something about 1 pin showing less voltage then another so he went with the higher voltage pin.
I've set mine to keep recording for 2hours after shutdown and all good, no quirks.
HeyI too used this quide and connector to instal blackvue DR650 2ch dashcam with power module in my Redline.
