lmoengnr
Donating Member
- Jan 15, 2012
- 6,977
- 45,658
- 113
- Location
- Sunbury Vic.
- MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Pretty sure school holidays has started...
exactly why i didnt mention that. you questioned the anonymity. warnings and bans are for private chat not flexing.He's making comments (about cammed LS's) but they are full of falsehoods so I'm calling him on it, I don't see anything wrong with that. If you want to contribute fine, if you want to contribute dribble that is fine too but when you are trolling with bad info you can expect to be challenged. Seriously, he talks about his SSV that's cammed like a W557 which is nice except the W557 is a blown motor (LSA) so either he is really stupid of he is full of it.
to me, it looks like a hit and run and we probably won't see him for another few months before he imparts another pearl of wisdom.
If you would like I can try and dig up the PDF of the dyno run!
Hi @wagon37
After you get the OBDIi reader , start monitoring the cylinder misfire PIDs . Check the actual and the history.
It could give you a clue were to start. Once you know which cylinder has an issue you can start swapping plugs , leads , coils around.
But first measure the injectors.
When the injectors impedance on my ls3 we’re out of spec. The rough idle would come and go.
Cheers for that mate. I was just re-reading your post in another thread about checking the resistance on the injectors. Any tips or tricks there or is it a pretty straight forward task?
Also did you get any warning lights associated with the rough idle?
Cheers.
Wagon 37 who did the work on your wagon?
440hp at the tyres is a pretty decent number!
What are the specs of your cam if you dont mind sharing.
Also what are the specs on your exhaust and intake
Have you run it at the motorplex yet?
Sorry for all the questions.
Not having a go like some im just curious. cheers
It is pretty straight forward, unplug the injector connector can be a bit tricky but not that bad .
I had engine light on once or twice and the code was related to cylinder misfire. But several times the idle was rough and there was no engine light. However the misfire counter was increasing on cylinders 4 and 6 if I remember well. I guess it wasn’t misfiring enough to throw a code.
