Great idea with priming the lines like that. Saves a sore leg from pumping it through. Good to see it getting closer to being finished.
Thanks all, was a lot of work but in a weird way really satisfying. I reckon I could improve them a little, a couple of the radiuses on the bends are a bit clunky, but they will do for now. Be a nice future week end job once its all up and running to just remove a couple of the lines that the bends arent perfect and make new lines up.
I received the 5/8 fuel hard line and fittings yesterday. Had a good look underneath the car at how and where to route them last night, was a lot of head scratching. Not sure its going to be that easy. The issue is its just so bloody crowded around the rack/extractors/steeling/gearbox where the stock lines would run. It would mean the fuel rails will literally only be a few mm from the exhaust. I had a look and there is quite a bit of room in the transmission tunnel over and alongside the gearbox. So I am thinking about maybe routing it up through there and bring it to a bulkhead behind the heads on the firewall. No sure if anyone else has run into the problem, theres maybe not so many VR's running larger fuel lines, but interested in any one elses experience.
