VT Brakes onto VS ute
Da_Street_Sleepa
YAY!! BONGOS :P
Toowoomba
VS Commodore Ute
hey guys,
Can anyone tell me if its possible (and worth the time) to install the front brakes from a VT into my VS S3 ute.
If so, how big of a job is it??
All i want to do is put the rotor, caliper and caliper bracket onto the front without any major modifications to the suspension.
Thanks.
Decicrate
BrisVagus
VS L67
The VT brakes are a direct bolt on. You will need the calipers, rotors, brake line (I recommend that you get the braided ones) and the hub ring.
The hub ring centers the rotor as the hub hole on the later models is a little larger.
If you have all the parts, it will take about 45 minutes per side to do and there is no modifications needed.
Some people will tell you that you need to upgrade the master cylinder and or the brake booster. I ran mine for years with the standard VS brake booster and master cylinder and had no issues at all.
Make sure you run a decent brake pad, I highly recommend REMSA from GSL rally sport (site sponsor) they are great all purpose pad.
Will will be amazed at the difference once you do it.
jgtoranalc
Adelaide, SA
Holden Statesman VR HSV 5L, Holden Torana LC
This is the kit I was looking at until I got told I can fit VE brakes instead.
Commodore VR VS TO VT BIG Brake Upgrade Slotted Discs HSV ALL Models Maloo UTE | eBay
You will need the Shim Adaptors and custom Brake Lines
Adaptor Shims Rings VR VS TO FIT VT 296 330 OR 343 Rotors HSV Commodore | eBay
Commodore VR VS With VT Front Calipers Front Only Safebrake Braided Lines | eBay
I'm not sure if their are cheaper options for the brake lines
But check the How to Guide here
https://forums.justcommodores.com.au/threads/how-vt-brake-upgrade.75831
Da_Street_Sleepa
YAY!! BONGOS :P
Toowoomba
VS Commodore Ute
Thanks guys,
First day on the fourm and i got all the help i asked for :) ,
Thankyou heapzz
Deuce
Super Stock
'94 VR SS V8
Personally I would recommend having an air compressor and small cut off wheel on hand,
Use it to trim you stone guard rather than removing them.
