VT Commodore Leaking Coolant from sump plug
Spooner
40
vt commadore
I have an interesting one for you guys.
2000 VT commodore, 200k on the clock, started running rough once warm. Checked under filler cap, milky oil. Head gasket was my diagnosis.
Pulled off the inlet manifold and the gaskets there were stuffed, however i already had a gasket kit and the bolts so pulled the heads just to make sure they were ok. Head gaskets looked fine.
Cleaned the heads up, re-installed fresh gasket and torqued down following the sequence. Re-installed inlet manifold, using gasket maker in the corners between the block and the heads and put it all back together before dumping the oil.
while the oil was draining, i topped up the radiator with coolant and flush treatment, only to hear a dripping as water made its way through the motor and out the sump plug hole.
Ive since pulled off the inlet manifold again to make sure seals are properly in place (they were), and re-checked the torque settings on the heads.
I have also replaced the water pump with a brand new gates unit, sealant on gasket and on water pump bolts.
topped up and same problem.
have compression tested all cylinders and are all fine.
Im so over trying to work out where the coolant is getting into the block.
My last idea is the timing cover?
any ideas would be appreciated
Thanks
Dak
Wanganui, NZ
VX Acclaim
I think, don't quote me, there is a cover on the rear of the block that can cause this, gearbox out job.
gazac
Riverstone
VE SV6
I broke a transmission line in the radiator & got Automatic transmission fluid in the water, what a mess
I needed a new radiator, heater pipe seals, water pump, all gasket & seals replaced, system flushed out,
it took 3 weeks to get it all out after many flushed outs, the thermostat had to be replaced & seeing
on a VE 3.6 it is at the back of the motor the gearbox had to come off to get to it, they did flushed the
gearbox & replaced the gaskets.
When they did the work they also found bad engine mount & transmission mount that had to be replaced
All up $2000 with a service, but I must say it is now going great.
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
there is an oil feed passage on the rear crankshaft plate that is also next to where coolant is blocked off by the plate, mayb check that plates gasket. i had to replace mine just recently except i had coolant leaking externally from this seal not internally. it would be a bit of a bugger if its not this gasket tho as above said gear box has to come out just to do the job. i guess u get to replace the rear main seal while ur at it tho.
Spooner
40
vt commadore
ok thanks guys. It sounds as though its trickling from the front of the motor though? do i have to take the gearbox off to get to the rear cranshaft plate?
Thanks
wrx884
WA's ASR Rep
39
yep or motor out lol but its easier to take the gear box out.
if u can hear it trickle from the front mayb it is timing cover? hopefully its not cracked
