VT low beam headlights not working
SarahL47
South Australia
VT
Hey, the low beam headlights on my sons VT 99 are not working at all. Tail lights are fine, so are high beams. There is a click when turning the dial. I don't have a multi meter. Would changing the relay and putting in new globes be the best place to start. Thank you.
dirty hands
ipswich qld
magna
unusual to blow both lows at the same time ....unsure if it could be the light dial
cant remember is there is a separate fuse ...... or relay for the lows
are the dash lights and parkers working
to do a simple check change one bulb
diy check a two or three pin bulb works ......or all in one hi low bulbs
get a length of insulated wire ..strip of the ends of the plastic insulation attach one wire end to one battery pole
rest one bulb terminal on the other battery terminal
touch the other bulb contact with the loose wire
SarahL47
South Australia
VT
I thought it was unusual too. That's why I thought something has thrown them. Have changed the headlight fuse probably was no point as they were and are working on park and high beam. Yes dash and Parkers are working.
Thanks will try testing the globes that's an awesome way
Immortality
Staff member
Sth Auck, NZ
Swap over the low and high beam relays and see what happens.
I have had 2 low beam bulbs blow at the same time, one failed spectacularly and I think took the other one with it somehow which is odd because each headlight has it's own fuse.
SarahL47
South Australia
VT
Thank you all. I made sure the horn worked and swapped the horn for the low beam. He now has working headlights but no horn. Will buy a new relay tomorrow, now I know what the problem was. Love the easy fixes
Andrew bell
45
Newtown
Vt commerdore
I did have low beam but after awyel thay tern off and my dash light terns off as well is there a fuse to replace or how do I fix this please help I can't drive at night less I manely tern on hi beem
