VT not starting
Athena0
Hobart
VT executive
It really depends. Sometimes it’s absolutely fine and starts. Other times it won’t start at all. For the whole day even. But if it starts first go. It will be fine and continue to start fine.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
So, you have more than one problem.
This pic is from @Glaze thread, vy v6 dfi plug pin outs. https://forums.justcommodores.com.au/threads/vy-v6-dfi-plug-pinouts.304627/
Here is a pic of his dfi plug. notice the colouring on the right hand pin?
That's what is called a burnt pin. It needs replacing.
I suspect your plug could be in the same condition?
Do you do your own work on the car, or do you send to mechanic?
Another thing l learnt was when replacing the dfi, it's good practice to replace the coils with it.
I just get mine from a wreckers. I also keep a spare and the tools to change it, in the car.
But l do my own work.
ephect
Donating Member
VS Acclaim V6
Next time it doesn't start try checking the 2 things below no cost and easy to check.
1. In park position, Add forward pressure the gearstick and see if it starts, if not try rearward pressure.
2. Check if the immobiliser light is out when you try to start it.
If 1 works then it's the neutral switch, if light on during 2, it's immobiliser/key contact issue.
