Ever taken note of oil pressure change when you have changed the oil?
Do you know what happens when oil gets pass the oil control rings and how it effects the oil?
Answer those questions then it makes it easier to understand how a full compression test would show it up
Just give up your digging a bigger hole.
Oil pressure change with oil change lol, unless your putting the wrong oil rating like 20w 60 in a engine that uses 10w 15 then the pressure will be almost the same, on cold start ups pressure will be always a little higher till the oil gets up to operating temperature then it will steady down, again monitored close to the pump, not by sump pressure.
Oil passing the oil rings gets burnt up causing what they call sludge / burnt carbon which can build up on top of your piston crowns and also block your oil filter giving you less oil pressure and fowling plugs to changing fuel mixture ratio, still no change to oil pressure unless the screen becomes blocked,
what your saying is testing the cylinder for pressure tells you oil pressure in the sump that is not so, slant engines always ware down more on the down side so you always get a little leakage back to the sump that's why they have a PVC valve to bring the sump pressure back to zero so no changers to pressure within the sump which will prevent pushing out your crank seals, if that was to happen your seals will be leaking, it also reburns those gases via the egr valve to lower carbon emissions.
You don't know if your oil pressure is low or high via the cylinders its that simple unless you remove your oil sensor and put on a pressure gauge unless your superman and have x-ray vision and can see your oil pump screen is blocked due to sludge from burnt oil..
