Lex
- Sep 19, 2012
- 5,886
- 5,253
- 113
- Location
- Geelong Victoria
- VT Executive S1 V6 6 speed Auto Wagon
Dfi can be the problem?Yes O-ring. Replaced that.
Replaced or switched out everything mentioned above. Supercheap Calibre coil pack swapped position s. (haven't done the module that sits under the coils).
IAC (might be GOSS) coming from Sparesbox, the tps from Repco was Goss. Spark plugs were an unknown brand that were supplied with the blue spark plug ignition leads. I think the brand was Eagle.
But I have swapped one of the original OEM leads through the positions and doesn't seem that is the actual problem.
Still driving the car around and the idle is still getting worse.
Can also be the dfi wiring. Can also be plug that goes to the dfi.
Can be a lot of things?
Start with the easy thing first (won't cost anything, til you find a faulty part). Start the car when dark or in the garage. Raise the bonnet. Look at the coils, see any sparking? If not. Take one lead of a spark plug or a coil. Then start engine, idling same or rougher than when all leads on?
You can check dfi plug by taking it of the dfi (7mm socket?).
I think thats enough for now. see how you go?
